Slow Mo with HVX
cane
During the investigate the HVX I would know.
How works the Slow mo function on the HVX ?
Is this a buttom option or just to look in the menu.
Is it possible to get shoot in normal motion record and suddenly get slow mo in the same scene or must I make 2 shots one in normal motion and one in slow mo ??(think about someone is running)
And than add later in one footage that means you have two scene's.
Ok Thank for the link David
So as I understand from the link it is not a buttom function you have to search around the menu that means you can not shoot in one and the same scene .
You don't have to go through the menus, you can create separate scene files for the different frame rates you wish to use, which are accessible through the six-position scene file dial on the back of the camera.
While you can switch scene files while recording, not all of the settings that are part of the scene file can be changed while recording. The framerate is one of those. Thus, you have to stop recording, switch scene files to select a different framerate, and then resume recording.
A better way of dealing with this is to always record at the highest framerate (60P for NTSC cameras, 50P for PAL), and then create slow-mo from that in software. Since you have two times as many frames as are needed for broadcast, you can easily slow the video down in post by merely not dropping every other frame, which is what your NLE does to convert from 60P/50P to the local broadcast standard.
