Then why isn't the GH4, or more other cameras encoding 4K at 400mps? or 800mps? or 8K at 800mps? Why is there any limit at all, if there's no difference in the amount of work the processor has to do?
Did I ever say that there should be no limit on encoding?
You can put words in my mouth all you like but you look like a fool with your idiotic statements.
The camera is able to throughput 200Mbps we know. The hardware, the SD interface, managing heat build up..... this is no the case for 8K or 800Mbps. Whoever mentioned 8K or 800Mbps? Having 'no limit at all' like you stupidly suggested is not feasable as you are limited to the throughput of the hardware and SD cards plus overheating. But, we already know that everything in the camera can handle 200Mbps.
It also has nothing to do with price and price is not part of the argument. Again, the hardware is there, it can do it easily at 1080p. If anything, its 'generally' easier for an encoder to encode at a higher data rate is there is less compression being performed.
As for the Bozo engineers, dont you think that they choose what date rate they want to give us? It's not a technical limitation that only the engineers know the answer to. As Snowblind smartly said, look at the GH1 and 2 and what was achieved with those. Not technical limitations at all.
I dont have an issue with the 4K data rate. It just perplexes me that they saw fit to give 1080P 200Mbps (even though it is all I) but 4k that has 4 times the info is limited to 100Mbps. I think it shows, getting back to the OP, that crippling cameras still happens. Don't all be so naive.
I don't expect it all for nothing and I understand that there needs to be limits but decisions that don't make sense are annoying.
Using a screen that is susseptable to burn in on your falgship hybrid camera, limiting the data rate on a 4K image disproportionately to a lower res 1080p image and data rate etc..... just doesnt make sense.
