Lenilenapi
Carbonite Member
I imagine these questions have been asked before but I can't find the answers so please bear with me.
I just bought a T2i so these questions are best suited to the T2i or the 7D
When do you feel you start to see noise in the ASA rating? Is 1600 still clean?
Can you see the difference between 800 & 1600?.
How bad is 3200?
Could you compare them to noise levels say on an EX-1 in gain?
Likewise what shutter speeds work OK.
Is 1/30 or 1/25 any worse on the Canon then it is on the EX-1?
I will use those speeds if I need the stop on an EX-1 or HVX. Is it equally OK on the canon?
what about shorter speeds like 1/100 and shorter. I've heard that you can get bad choppy movement as you shorten the shutter speed.
Thanks -
Lenny Levy
How bad is 3200?
Thanks -
Lenny Levy
