GaryNattrass
Ha ha we do still use analogue levels in TV and that is why PPM's are still used here in the UK. 0 or PPM 4 for line up and +8db or 6 PPM for max! ;0)
Levels agin, huh?
Actually actually dbFS is different that analog dbVU. First off they should really be written as dbFS16 or dbFS24, etc. As they vary depending upon the bit depth. What 0 dbFS is is the point where you sound level is using all the bits available. If you think of it you can record a louder sound with 24 bits than you can with 16 bits, and FS means Full Scale, so 0 dbFS is the maximum level you can record period. Levels above that do not clip, they do not distort, they just aren't there at all. In effect, they disappear.
On the other hand dbVU is measured at a reference level, because in general you do not know how much headroom your analog circuit has, so a safe reference level has been chosen for 0 db. Which is about 4 db down from the worse case setups, really good setup may be able to record fine at +20 dbVU which is the equivalent of 24 bit digital, by the way.
OK, those signals brought to a comparable level 16 bit is -12db, and 24 bit is -20db, which are pretty much equal to 0dbVU. The conversions are not exact but are plenty close enough to be considered the same in the real world.
I do not understand why in the world they did not all use the old analog reference and just say that 16bit has 12db of headroom and 24bit has 20db of headroom, and not confuse everyone. Well, I actually do understand why. Jargon is used to to confuse those who are not in the know and prove to yourself you are better than they are. That is why kid's gangs love to use made up or misused words. In other words, childish nonsense.
... so 0 dbFS is the maximum level you can record period. Levels above that do not clip, they do not distort, they just aren't there at all. In effect, they disappear.
Digital recordings have no wiggle room, at zero you are done.
I assume that, this previously asked question (asked with in mind, a Shure FP33 with a very decent preamp) can be answered with this:My question was, with a clean signal (from a good preamp), having the audio at an average of -20dBFS and peaking a little louder, can we bring that average (with a compressor) to something more audible in post? Will the quality be as good as if it's been recorded around -12dBFS?
With analog you calibrated with tone zero dBvu, but a professional mixer could handle +25 dBvu or so. Theoretically your tape would start saturating at zero dBvu but it's a soft top so hitting +6 - +12 was not often a problem.
Which is why digital is calibrated at -20 dBfs. There is no "+" in a dBfs scale so setting your "zero" at -20 gives you a similar headroom to analog. But a lot of this is to accommodate old gear and old workflows. If, as is usually the case these days, you are not going analog till you play back over speakers then you are largely free to record at any level that doesn't clip.
So, I'd be using the Mixer/Preamp (Shure FP33) slate to set the level at -20dBFS on the recoder (Tascam DR-40), and when recording audio, have the average signal at -12dBFS?BTW since it might have gotten confusing, while the tone is calibrated to -20dBfs you are looking to have your average signal on the recorder at -12 or so with peaks at -6 to -3. The -20 is get the analog gear set up to work well with the digital recorder.
Not true.
And "done" means digital clipping. Try to push your digital levels past 0: any data above what the signal can hold is simply sheared off, effectively creating a square wave. This digital distortion is in no way pleasant, like analog distortion can be in some cases, and there's no way to repair it.
And do any of you see that we are saying the same thing? Not there, done, digitally clipped all mean there is nothing above 0 dbfs.
And I am correct -12db 16bit, and -20db 24bit is approximately the same as 0dbvu. It really does depend upon your bit depth!
My notions are only based upon a BSEE and 55 years of experience, plus double checking them.
Not to get more off topic and confuse folks, but when I was a music recording engineer in the 80s (not to reveal my age), we used to set the tape machine's VU meters to MRL calibration tape and go 6 and sometimes 9dB over the 185 and 250 nanowebers flux level, so the meters where... read lower, but the tape was getting hammered. (tape saturation sounded great on some instrument) Can't really do that today, but there's a lot of plug-ins that try to duplicate that sound.
Interesting!... that is why the 0db reference level changed from -18 to -20 to allow two db of headroom on the metering scale to 0dbfs.
That's pretty much what I had in mind. My only concern was if the average sound is too low (below -12dB), would it introduce noise when adjusting in post?Well, what I do, now that I have the mixer, is use the oscillator to set 0db on the mixer, and -012db (16/48) on the camcorder. Turn off the oscillator. Then I use the mic gain control on the to give me -20db on the VU meter for average conversational level talking. That setting is going to change with the particular mic, distance, and how loud the persons voice is. The old "Testing 1 2 3" (grin). Then I turn on the limiter, just in case.
Is -18dB/20dB too low for an average audio? Haven't tested it yet, just wondering if it would be better to use the limiters and get the average signal a little more hot?In post mix, I can adjust things more exactly, but I find that I often do not have to adjust it in post.
Yes, as long as it works for one.It works, so even if it is different than how others say to do it, it is not wrong.
Does that sound like how you want to record your film dialog into the camera? Maybe? If you have a Hollywood budget.
Ok, that sounds good to me. I as afraid to record too "safely" and boost in post where it would add too much noise. But I'll try to find the sweet spot between recording hot enough and adjusting in post.Assuming your analog chain is not particularly noisy boosting the level isn't going to add a lot of "noise", but it will add it in proportion so balance between dialog and noise is going to stay the same.
From what I've tested quickly, the FP42's limiter aren't best, especially compared to the FP33, hence the price. I've tested the FP33's limiter with the DR-40 and even with very loud and aggressive sound, the recorder won't peak. Sound is crushed by the limiter (this was an extreme wind blowing test) but the recorder gets -3dBFS or -6dBFS, I don't remember the right number. All that to say, that on a "normal" recording (dialog), the limiter should be plenty good to get a clean track on the DR-40 as it doesn't sound limited like with a brick-wall limiter.With out bullet proof limiters you are going to want to record lower to have some safety margin, but how much you need depends on what you are recording. A sit down interview is not likely to have any sudden loud sounds (that you want) so you can probably push higher, other things you may have to go lower because they are very dynamic.
So, the average sound/dialog should throttle around -12dBFS on the recorder. I'll aim for that, knowing that the limiter will activates without ruining the audio.I use tone to set the recorder so the MixPre's limiters will prevent clipping and I try to record fairly hot, so my normal dialog is probably higher than -12 but not a lot.
Last time, using the feed from a console (without the mixer) I asked the sound guys to feed the music at it's higher volume, so I set the camera's input accordingly. Then I compressed in post and it was pretty good that way.If I can be there for a final rehearsal I will set levels then. Sort of like dialog/ production I will have the recorder set so that the limiters are clip proof and I'm peaking as close to -3 as possible with out the limiters activating.
Good advice, always trying to record on the edge, but never above that. I would have play safer, like -6dBFS. I'll experiment, trying to know the gear a little better!For all things I try to never go above -3 dBfs.
Depends, the FP42 has a little noise floor passed 7/10 on the volume knob. Below that, it's pretty good, but above that you can hear it easily. Sure, noise reduction can be applied, but still.Also since the mixer doesn't have to fight with a hefty noise floor you can let tracks get quieter than you could with analog.
I understand. Always nice to know there's a safety. After a couple times, you get used to know how to set the gear, so you don't even have to rely on it.I mention limiters a lot because I use them pretty much always but I try to never hit them. I use them as a safety net not as a level tool.
