GH2 Should I consider this monitor ???
djkoz
I just purchased the GH2 and I am looking to add a few necessary accessories, trying to keep the cost down but the quality at a reasonable level.
I am told that it is very useful to have an external monitor for focusing, framing and maybe color. Do you think this unit would be acceptable? Here is the eBay link and the specs. Perhaps the screen is too big??? or the screen resolution to small???
Thanks,
Dan
http://www.ebay.com/itm/7-Inch-On-C...977?pt=LH_DefaultDomain_0&hash=item5648d80c79
At a Glance...
  • Ultra long 10 Hours working time
  • Super bright 1080P HD DSLR 7 inch monitor
  • Anti-glare screen works great even under sun light
  • High Contrast Ratio: 500:1
  • Wide viewing angle: viewable 120 degrees horizontally and 140 degrees vertically
  • HDMI, and VGA video inputs
  • Comes with HDMI cable and remote control
  • Full image control: color temp, red, green, blue and more
  • Connects to hot shoe
  • Uses standard tripod threads for mounting
  • Similar as INS-LCD15, but with much longer battery life
Specifications:
  • Screen Resolution: 800 x 480
  • Resolution Support: 1920 x 1080(max)
  • Screen Size: 7 inch
  • Display Ratio: 16:9, 4:3
  • Brightness: 450cd/m2
  • Contrast: 500:1
  • Viewing Angle (degrees): 50/70, 70/70 (L/R, U/D)
  • Signal Input: -HDMI
    -VGA
  • Adjustments: - Image flip
    - Image invert
    - Brightness
    - Contrast
    - Saturation
    - Tint
    - Horizontal position
    - Vertical Position
    - Red, Green and Blue adjustment
    - Color temperature: 6500K, 7500K, 9300K
  • Remote Controller: Yes
  • Mount: Hot shoe (uses standard tripod screw)
  • Power Source: 6800mAh removable battery
  • Battery Charger: 100-240V wall adapter- 12V output
  • Battery Life: 10 hours on full charge
  • Power Consumption: <8w
  • Languages: English, Chinese (simplified), Chinese (traditional), French, Italian, Dutch, Spanish, Japanese, Korean, Russian
  • Dimensions: W: 190 x L: 128 x D: 40 (mm)
