highdefvideo
I shot some clip using DV 16:9. When I try to capture with premiere, only the HDV device control is "online". I can control the VCR functions (play, rewind, ...). But in that mode premiere cannot capture DV signal. If I select the "DV device control", all the VCR buttons are grayed out and I also cannot capture the DV clip.
Never mind. How do I delete this post??
The answer is to force the signal setup into DV mode. The first time I was in this menu it was grayed out, so I couldn't use it.
