Shooting HDV and capture as SD
ihatedv
If you shot HDV 16:9 on let's say a HVR-A1U and captured as SD. Would it retain the 16:9 Ascpect ratio?
It should but you may loose quality. What I have done in the past is import the HDV footage into a SD project and scale down the HD footage to match the SD footage. The result is a great looking SD video!
It would depend on the scaling that the camera does, some camera does it better than other. The answer is yes, you would get 16:9.
Rather than rely on the camera to downscale the image, I suggest using VirtualDub to do the downscaling (use Lanzcos resizing).
