Just to give you an idea of what the FS7's Custom mode can deliver. I have a spate of concerts just prior to Christmas every year ... Most lighting techs want their work to look good and the monitor reference helps them deliver that.
I think you will find the highlight handling, dark detail and noise levels pretty acceptable in the following clip. Custom scene files set up correctly on the FS7 can deliver up to 12 stops of dynamic range and the FS7 Custom mode is totally capable of handling anything that is reasonably lit. Three FS7's running the same matching scene file matrix makes for a quick turn around for DVD and BD production and quick is what we need with the concerts as we are usually into DVD/BD duplication within 48-72 hours of the completed multicam switch, edit, graphics and DVD/BD encoding. We don't have the time to use LOG grading and NR like Neat Video which really has to be set up scene by scene to get the optimum out of it. WYSIWYG with minimal post adjustments is the order of the day for us for a fast turn around. The following clip is from a mid shot camera and was shot in HD 50i S16 mode with an MTF B4 to E-Mount adapter using an 18 x Fujinon F1.6 B4 broadcast lens. Shot in 50i as that is what we use for the DVD/BD production.
Chris Young
https://www.youtube.com/watch?v=hj3wOzL1Y-Q
I think your approach works great - though obviously you do have some light to work with (and enough to make up for the light loss from the B4 adapter).
The worst situation unfortunately is if they are lighting with LED's because they can be extremely saturated - way beyond what a camera can handle.
