Evangelos Achillopoulos
Last Wednesday I was having these two things together...
I have already start, building the connection parts and I also tested the possibilities...
As is the relay works in the FF35 frame size, it needs a slight modification for the S35... By next weeks everything will be tested and charts will be available...
As you can see the relay is totally modular, we can change the back focal distance, the mounts, and the front focal distance...
