I shot several clips at 1080p 60fps, when conformed to 24fps for slow mo everything is fine as usual. Problem is in Final Cut Pro these files when I add a cross dissolve, fade out, or basically any transition I get a weird flicker in the clip. It's like it goes bright then dark.
I do not have this problem with the regular shot 24fps nor with my other footage of 60fps at 720p with GH2 as a second camera.
My only problem is with the 1080p 60fps conformed to 24fps, I get a weird flicker in all of the clips when applying any transition, Help Me out!!!!
