Sending Video to Capture Station
sethian
Hello, I have a Canon Vixia HF 200 video camera and we are trying to use this camera to send video to a capture station using the stereo video cable with the yellow-red-white plugs from the AV out plug on the side of the camera to a switch. Although this setup works for a Sony in standby with no additional adjustments, no matter whqt we did we were unable to get the output from the Canon to appear on the capture station. It recorded to the Flash memory fine and the image appeared on the viewer, but there was no output signal. We were also unable to find a menu adjustment to enable this feature, but there is a port so we assume that this can be done using the Canon. Can anyone provide assistance on how to do this? Thanks.
Did you try it on playback, if that's not what you're trying to do to start with? I don't know that specific camera, but have you read what the manual says about the outputs? Sometimes they don't work as anticipated.
