GrahamH
I'm not sure of the specs of the GH2's 2.5mm audio port so I need some advice on which wired lav to buy.
An existing unpowered condenser lav that I had lying around records a signal via a 3.5mm-to-2.5mm adapter, so clearly the GH2's port supplies power to the mic. But that lav's signal was way too hot even at the lowest recording level.
So I've just tried out an Audio-Technica ATR-3350 and the results were not good - I kept getting regular bursts of static and a high noise floor. That mic supplies its own power so I'm wondering if the two power supplies are conflicting? Or perhaps I received a faulty unit? (I'm confident the camera, 2.5mm adapter and port are all OK as my Audio-Technica AT822 stereo mic works great.)
Anyway, what do people think of this SoundProfessionals lav as the next one I try - this model takes it's power from the port. Or does anyone have a better recommendation, preferably under $100? http://www.soundprofessionals.com/cgi-bin/gold/item/MS-LAV-1
Thanks.
Thanks.
