CraigM
I always base and calibrate my digital audio at -20db as so many do and recommend. Easy to do on a traditional camcorder or external recorder by sending tone, not so much with a DSLR. Testing out a 1D C with a Sound Devices MixPre-D for recording audio in camera for run-and-gun work and nat sound when I don't have a audio person handy. I've used JuicedLink products on a 5D and d800 setting manual audio recording to +1 and letting the external pre-amps do the work with good results (they have no tone for calibration).
Now that I have a MixPre-D I thought I would test with tone to see how the 1D C handles audio and where my base with this mixer and camera should be.
If I set the 1D C's manual audio recording to +1 and run tone from the MixPre-D I get a consistent -30db in FCP/SoundTrack Pro. Seems pretty low for a base. If I set the camera to +10 clicks it hits -20db right on the money (where I want to be for calibration) (+20 clicks puts it hotter at -12db).
So I am curious if I am approaching this correctly and what others might do. Go with the +10 clicks for a solid -20db base, or stick with +1 and crank the MixPre-D up some more realizing the pre-amps in the MixPre-D are far superior, but at what cost if I have to go 10db hotter all the time.
On a side note the head phones out of the 1D C for confidence recording via the return on the MixPre-D is pretty weak, useable, but could be much better.
Thanks for any input, no pun intended.
