modus
What I'd like to do: Jam sync the time codes between two c300s and utilize the SDI Record Command feature.
I can't seem to get the SDI rec command feature to work. I've gotten the timecodes synced, but the b-cam won't respond to the a-cam's trigger. Can anyone explain exactly which settings I should be using and which ports should be linked together? The manual isn't really helpful with this, as far as I can tell.
Also, once the time code is synced, do I have to keep the cable attached? Will they drift if I remove the cable?
Thanks for the help!
