LannyBirch
Does anyone know how to remove the vertical letterboxing in FCP?
I shot some stuff on p2 in SD using 4:3. When I bring the files into Final Cut it shows the 16X9 frame with the black bars on the sides to crop off the 4:3 field.
When I export it out to quicktime or using compressor it exports it with the letterboxing intact. Is there a setting to eliminate this? And is it in the import or the export part of the process?
I apologize in advance if this is a basic FCP question I should know the answer to.
