Hence my concern, yes.Antoine_Fabi said:that's very very scaring for any professional use...
I'm certain of it, yes.Do you think the chroma aberration is coming from the lense ?
Are you referring to the SD footage from DVInfo (about the construction work) or the mini35 footage on DVInfo? You shouldn't see any at all on the mini35 stuff, as we used top-notch Cooke S4 prime lenses. Regarding the construction footage -- that was shot in DV. I would expect that the much lower resolution (about 1/3 as high) would mask most of the aberration, as the overall format can't resolve the full detail.I dont see that much of color aberration in the dvinfo.net footage though.
Is it possible that there is so much variation between two cameras ?
The examples of CA that I've seen on the FX1 do indeed appear to be milder. I think the HD100 exaggerates it because of the focal length of the lens -- CA is more pronounced at the telephoto end, and on the HD100 that means 88mm, vs. 54mm on the FX1. So it's possible that the lenses may be in the same class at equivalent focal lengths, but that the longer telephoto of the HD100 exaggerates the aberration. I don't know, just guessing.Spiff_2 said:Urg. That chromatic aberration looks worse than that on my FX1. Though I must admit - the effect on that wine glass is pretty cool.
-Spiff
I certainly hope so. Like I explained before, I don't think that's what's happened here -- I think the very process of shooting in SD may mask the aberrations to a good degree.Antoine_Fabi said:Is it possible that there is so much variation between two cameras ?
Barry_Green said:I believe that JVC is holding up the US release until they get a better handle on quality control. I wouldn't be surprised if JVC USA is now hand-checking every camera that JVC Japan ships them. And I think that's a good thing. I look forward to reporting on what the US-spec camera delivers (although that wine-glass footage was shot on a US camera that was identified to me as a "production model").
