T2i SD Cards & Magic Lantern
super_plus
Just wanted to see what kind of results people are getting from their SD cards for those using ML on T2i's.
I'm currently using 16gb Class 6 Transcends and able to record up to -14 Q scale or 50mbs CBR without issue. Anything over that stops pretty much immediately.
What kind of results are people getting with Class 10 cards? I'm curious what the ceiling is.
class 10 Transcends actually aren't as fast in real world testing as, say, Sandisk or Lexmark Pro series. The class is a *minimum* rating... there are some class 4 Sandisk cards that can probably outperform your Transcend. Just saying- you should be comparing brand AND class, not just class. Or just do one of those read-write speed tests to get the actual numbers for your actual cards, and then you can do the match accordingly to see how much better one would be than the other.
That's what I was going for. There seems to be a disparity between brands and I want to see what kind of results they are getting with their respective brands/class etc.
