scopebox - urgent help
phazelee
hey guys
I'm having a little difficult time with the scope box program.
I did a little test on it, but some reason it's showing interlaced lines.
On my dvx100a, its settings are [ squeeze, 24pa, 30 shutter speed ]
On my scopebox program, it's set on [ DVX100A, "best" fps, interlaced ]
When I did a test of my fingers moving rapidly fast, I keep getting this. I tried raising the shutter speed faster but i was still getting interlaced lines.
please help :)
this is an issue of pulldown.
thi will happen every 4th and 5th frame.
If you are shooting 24PA then you must edit in a 23.98 timeline
if its 24p, then you shoot in a 29.blahblah timeline and check the pulldown.
I shot 24pA, and I imported into After Effects 7.0 and did a 'guess pulldown'...and had the timeline set at 23.98....but still i see interlaced lines in my hand.
The weird thing is when I move the window around, the interlaced lines does some weird movements also...is that normal? hm.
