Since Panasonic hasn't uploaded any scene files for the HPX250, nor have I seen anything online, I decided to try and modify the files for the HPX300. I figured it should be pretty easy since the '250 and '300 share the same chipset.
First I downloaded the HPX300 scene files I wanted from the Panasonic P2 site. (link below) After opening the scene file in TextEdit I looked at them and noticed that the file format is not that different than the scene files for the '250. I chose the DIGINEG, FADED and CRUSHED scenes, just because they looked like something I would use.
First I inserted the SD card into my MacBook and opened both the '250 and '300 scene files side by side on my desktop, the '250 has a few extra lines such as "SYNC SCAN TYPE" and "DRS on/off" I didn't really care about those too much since they are easily accessed from the camera. Next it's just as simple of copying over the individual adjustments from the '300 file to the '250 file. Make sure you only change the values, and not copy and paste the whole line. Also do not delete any lines, or try to load the HPX300 file back into your HPX250, It will not work.
After saving the file back to the SD card, I inserted the card into the camera and loaded the scene file I just created. It worked
rogar-BigGrin(DBG) Granted it's probably not an exact match as the HPX300 scenes but it looks pretty damn close. And it took less than 5 minutes from start to finish.
Maybe we can start a scene file thread so people can share their custom files?
http://www.panasonic.com/business/provideo/scene-files.asp?model=HPX300
