They should be fine with both versions of Sanity.Question: I have Transcend 16GB class 10 cards (20MBPS). Will they be sufficient for Sanity 4 or 5? And if so, any idea in terms of footage-time?
This does not sound normal. What card are you using?I like the images I get from Sanity, but sadly I cannot stick to it due to frequent write errors and playback failures. Resetting, formatting, reloading-none of it alleviated the symptoms.
Some of these fast cards have a problem where they momentarily drop way down in their write speed, causing a write error. I'm not saying that's the issue, but it might be. I highly recommend that you try different cards. I developed Sanity using Sandisk Extreme HD Video 30M class 10 cards, so naturally that would be my prime recommendation.Sandisk Extreme 45MB/s Class 10
SANITY 4.1
Here is an update for SANITY with vastly improved stability for the PAL version. This sucker is STABLE. In fact, so stable that I was able to raise the data rate in FSH/SH mode to 36M. So, there's better picture quality, too.
I've also updated the NTSC version, although there was nothing wrong with version 4.0. I simply applied some of the things I learned from the PAL version, to make it even more stable. Call it preventative maintenence.
Again, what SANITY is about is top picture quality is ALL shooting modes with reasonable data rates and 100% reliability.
Hey RatLab, here's a zip attached with Sanity 5... if you trust me that is :0
Cheers!
card storage is fat32 which has a file limit of 4gb. if the recording reaches 4gb, it needs to SPAN to a new clip.Hi jmw,
thanks you all for your info about Sunity. It will also be my choice. I only do not know, since I am the beginner, what does it mean SPANNING. Can somebody describe with other words, what it is. At Sanity 5 the spanning shall not work in HBR mode on Panasonic lanses.
I have the sandisk 95 Mb / 32 GB card. Will it work with this one. The other one is an Class 10 / 30 MB /16 Gb from LD. Any recomendation?
Sorry, I have an GH2.
