Anyone know what the field of view difference would be between ef version on 64xl speedbooster compared to the native mft version.
So to be clear: EF mount Samyang 85 on gh5 with speedbooster = to 105mm
MFT mount Samyang 85 on Gh5 = 180mm.
Yes?
http://en.wikipedia.org/wiki/Flange_focal_distance
Nikon lenses can be used on more cameras than Canon lenses can be. Simple matter of math, the relative flange lengths.
Additionally Canon EF lenses which lack a manual aperture ring (which is nearly all of them) need electronics to control their aperture, which makes it much trickier, more expensive, and as a general rule slower to market too, to make adapters (and related products, such as focal reducers) for them.
See the typical five fold difference (or more!) in price between a typical Nikon G adapter vs a Canon EF one from China as an example.
Don't get either mount, get it in Nikon F mount:
http://ironfilm.co.nz/rokinon-cine-lenses/
The glass inside the lens with any of the mounts from Samyang/Rokinon are exactly the same across the range of mounts offered, thus you might as well buy it in the mount which gives you the MOST flexibility for the future in terms of what you can mount it to. Thus that means buying it in Nikon F mount.
When it comes tofu manual lenses I would agree but what if somebody wants to use electronic lenses someday? The Nikon mount lenses will always be dummy lenses. No optical lens stabilization, no communication with the camera, no auto focus or control of the iris. Going the Nikon route can be a bit limiting if one wants the lens to function as they would expect the features they paid for to actually work.
With that said Nikon does have a major advantage and that is that is rarely ever has any issues on adapters. EF lenses have very sloppy support for electronic control. some lenses work and others not so much. Some EF lenses are even known to freeze the camera. That will never happen with a Nikon mount adapter because there are no electronic contacts at all. So you sacrifice features of the lens for 100% stability and support.
Finally EF-S lenses can be a PITA and sometimes require cutting off part of the mount in order to fit on adapters. Again Nikon just works no matter what lens you have. If it physically screws onto the adapter it works.
Nikon is not going to license their electronic control protocol to another camera maker, so kind of limits having a smart adapter with so few electron controlled Nikons compared to their other F and FG lenses.
Cheers
Cheers
That won't work well on an MFT camera, because EF lenses require active electronic adapters to provide aperture control (as well as auto-focus and IS features). As IronFilm points out, if you want a speedbooster-compatible lens with straightforward manual lens control, Nikon-mount lenses are the most MFT-friendly option. This does NOT include the recent electromagnetic-iris "E-type" lenses from Nikon and Tamron, as discussed above. But most Nikon enthusiasts in the MFT ecosystem aren't looking to use the latest electronic models, we're into the vast range of classic MFT and speedbooster-compatible lenses.Going EF requires an extra investment. You can use a $20 dummy adapter for the same focal length as the m43 mount...
