Grant Peacock
Hi all,
Wanted to share something, before I forget. This issue can be elusive - you're not sure if you should be focusing on feature sets of the recorder, or the camera. Also tricky because of the age of origination of camera and HD-SDI.... 'What trigger features did they have avail in SDI signals, back then?'
Here is how I obtained that sought-after 'red box' around the Samurai Blade screen (indicative of recording) - in my PDW-F800, I went to Maintenance menu, page M12, CAM CONFIG 1, HDSDI REMOTE I/F - changed from (whatever it was) to R-TLY.
I can't even tell you what all these sub-menu abbreviations stand for. Sometimes, you just get lucky. This is great for me tomorrow, as the camera will be up on the right shoulder for at least some of the shoot, and it's an almighty pain in the butt if you have to keep touching the ATOMOS screen to manually record. And you simply will not catch every shot under those circumstances. With this menu adjustment, the Samurai Blade will now follow the REC button on the camera (inside the Blade menus, it is set to follow Sony from amongst cam manufacturer choices).
Happy shooting!
Grant.
Happy shooting!
Grant.
