hopkins802
Are there an S1H or S1 users here? If not, is there a better forum thread for questions about that camera?
For the S1 owners/users, any info or insights on the S1 for those of us still using (and kinda envious) GH5 users?
I've been watching the S1H closely and it looks pretty awesome in a lot of ways. It's weird that it has more limitations than the GH5 though... hard to justify that when $1-2k cameras have fewer VFR and codec limitations etc.
The S1H doesn't have more limitations than the GH5. The S1 does. The S1H has more codec and VFR options.
S1H only does 4k60 in 4:2:0 and cropped. Pretty sure the GH5 doesn't crop the sensor or lower sampling to do 60fps.
As Dingo pointed out, the GH5 starts cropped to begin with.
I cannot see any quality loss on any S35 vs FF modes, and have not read that any exists. Lowlight and DR is also maintained. Actually, I just run the camera in S35 mode full time and only switch to FF mode if I need to go a bit wider. But, that's because I run a lot of slow motion and don't want to mentally switch between thinking in two different FOVs at same time. I also run EVA1 and GH5 with speedbooster, so keeping it in S35 makes all 3 of these cameras essentially operate with the same FOV.
in general its silly to make comparisons between the gh5 and the s1H.
basically its simple- is the S1H 'better" than the gh5 - the short answer is yes it is.
Do you need to upgrade to it- only if you are not happy with what you have.
its very simple the S1H has better dynamic range, better color especially skin tones, Time code, 120 FPS in 10 bit 1080p better low light via dual Native ISO more frame rates and codexes white maintaining IBIS etc. which doesn't mean you NEED it if you are happy with the GH5 there are people who are simply shooting Natural PP don't care about frame rates, never use Time Code and never need top shoot beyond iso 1600- and have a vast m43 lens collection -These people will not benefit from switching.
But the S1H is better its that simple.
QUOTE=stoneinapond;1986809909]You say it's silly to compare the two cameras, and then go on and compare them....:huh:
You should have stopped at the first line.
