S-Log2 noise
alex1
We recently did a shoot in S-log2 and I noticed the shadows are very noisy. We exposed correctly, but is this normal?
The trick with the fs700 sensor is to shoot at the native ISO of 2000 in slog2, over-expose by around 2 stops and then bring the grade down by 2 stops in post. There is a lot of latitude at the upper end of the dynamic range as opposed to the lower end. This is fairly limited with the internal 8-bit codec, but with 10 bit prores from the Odyssey 7Q, this workflow yields excellent results.
Check out the below image for example. On the left it is perfectly exposed to a colour chart at ISO 2000.
The image on the right was shot exactly two stops over and then brought back 2 stops in post.
The "perfectly" exposed image on the left is quite noisy in comparison.
The image is an 800% crop of one of the dark grey squares on the X-rite colorchecker passport to show the difference.
The more you under expose, the worse the noise will get. (And it doesn't have to be by much)
Nicely demonstrated. And with the Odyssey7Q+ you can preview exactly what you'll get using the Exposure Compensation LUTs. Download the matching LUTs off our website and follow our tutorial to apply the LUT in Premiere or Resolve. Very easy and excellent results.
