Wesley Byram
Something that has been mentioned by more than one reviewer online, is that the RX10's internal codec is a bit weak. Fortunately, with the clean HDMI output, an external recorder could be a workaround. I didn't see any direct side-by-side comparisons so I decided to actually test this out first hand. To that end, I shot a short, high-detail clip deliberately designed to stress the codec: Handheld, F4, 1/160 shutter, neutral +3,+3,+3. Video was recorded both internally and with a Hyperdeck Shuttle.
These are 1:1 crops of matching frames from each recording:
Internal AVCHD:
Uncompressed via Hyperdeck:
Even without pixel-peeping, the difference is pretty obvious. The interally recorded image has a ton of detail smudged out. Now, bear in mind that this shot was pathologically designed to break the codec, so most of the time, you shouldn't see this much difference.
Of course, we already know that AVC/h.264 footage can break down if you throw too much detail at it, expecially with heavy camera movement. That said, I decided to see how Sony's encoder stands up to another. I took the uncompressed clip and re-encoded it to AVC with x264. Settings there are 23mbps CBR and 1-pass encoding to roughly match the specs of an AVCHD file.
The result:
So, it looks like there's some room for improvement in Sony's implementation here. The x264 encoded file is much less smudgy than the camera's version, even though they are both using h.264 at about 24mbps.
Internal AVCHD:
The result:
