Ben Sliker
Pain In The Ass 2.0
Rosco LED Lite Pad Kit (6-Lights) with case - $1850 OBO. B&H sells a similar kit for $2100. PM me with offers.
Hey guys, I've got a Rosco 29024000 Lite Pad Kit in like-new condition. I've used it on only two occasions, maximum 2 hours of use on 4 of the 6 pads, haven't even used the other two! These are rated for 60,000 hours!!!!
More info on the Lite Pads: http://www.rosco.com/us/video/litepad_ho.cfm
These are the HO - High Output versions, and 6000K Color Temp. Comes with power, splitters, dimmer, Battery Adapter, Brackets for mounting, car power adapter and more.
These are great for the traveling shooter, a quick interview kit, or for sticking a light in a very small space. In a Pinch, you can gaff tape on of these little guys to pretty much anything. I flew to Utah with these and my D7000, carry-on, no baggage fees!
More stats:
Dimensions
Circle 3" (diameter) x 0.37"**(76.2 x 9.4*mm)
3 x 6 x 0.64" (76.2 x 152.4* x 16.2 mm)
3 x 12 x 0.64" (76.2 x 304.8 x 16.2 mm)
6 x 6 x 0.64" (152.4 x 152.4 x 16.2*mm)
6 x 12 x 0.64" (152.4 x 304.8 x 16.2*mm)
12 x 12 x 0.64" (304.8 x 304.8*x 16.2 mm)
Weight
3" Circle: 0.1 lb (0.04 kg)
3 x 6": 0.8 lb (0.36 kg)
3 x 12": 1.3 lb (0.58 kg)
6 x 6": 1.45 lb (0.65 kg)
6 x 12": 2.25 lb (1.0 kg)
12 x 12": 3.95 lb (1.8 kg)
Light Output
At 18" (457.2 mm)
3" circle: 9 fc
3 x 6": 23 fc
3 x 12": 37 fc
6 x 6": 34 fc
6 x 12" 60 fc
12 x 12": 90 fc
More stats:
Dimensions
Weight
Light Output
At 18" (457.2 mm)
3" circle: 9 fc
3 x 6": 23 fc
3 x 12": 37 fc
6 x 6": 34 fc
6 x 12" 60 fc
12 x 12": 90 fc
