Mike Kobal
keep in mind first half of the pan is extremely fast...
cheers,
mike
I was thinking a great test would be to somehow mount or stack all the cams on top of eachother on a tripod head, then you would be making the exact same motions with each ...
Or get fancier and use some further scientific method to measure exact read/reset times and then just publish the numbers...
Thanks for the test regardless... it's cool you had all those cameras there at once!
thanks Matthew, yes of course. that's how it should be done. too much work to built a rig but i might do it with the 5d2 and 7d since i will be mostly shooting with those two now
