Rode VideoMic Pro is in stock
Did you also order a 3.5MM to 2.5MM adapter?
Nope but radio shack FTW. Also grabbed a mono to stereo adapter as well.
Here it is on my X-grip with the GH2:
Is the red LED stuck ON while the switch is in the OFF position on anyone else's? It's supposed to come on when the battery is low, when in the ON positions. I only turned it on for about 30 minutes on Monday, and it's just been sitting in storage for 5 days since then. When I got it out tonight to play with it, the red light was on. The battery is not low, I even replaced it, and the red light is still on. It still works fine...sounds way better than my cheap Azden compact shotgun, but if the red light doesn't turn off, I guess I'll be returning it. :( Just curious if anyone else had the same issue.
Mine does not have this issue.
