Review of lighting/set for cooking show
I like the lighting - I'm not so sure about the whiteish clothes - with white everything, you might need to work on colour saturation a bit - to bring out what colours you do have. The girls need a makeup artist to perk them up - I'm not suggesting clown type lipstick, because the look is natural, but just some subtle highlights to create some definition. As there are no mics visible, are you booming, or are these just mock-up shots? Considering the number of high sheen flat surfaces, the lighting is pretty good for a cooking programme!
+1. Just don't let them wear black. That level of contrast would wear on the viewer after awhile. I'd suggest dress them in colors, not neutrals as the set is already all about neutrals, and you need some visual contrast to make it (and them) interesting.
+1. They need a trip to the local Bobby Brown counter and some lessons in "HD makeup", which is quite different than "street makeup". What HD makeup does is make them look on TV like street makeup makes them look in person.
+1 again. Good control of the reflective surfaces. Just be sure your lighting extents to the ends of the counters your talent can get to. Many cooking shows let the talent wander up and down the counters, and it's disconcerting if they can walk into a region of light fall off.
Best I've seen is a PBS show called America's Test Kitchen IIRC. Huge space, huge lighting grid, must be hundreds of flo lights hangin'. But their talent can walk anywhere in the space and the lighting is always spot on.
+132 on all the white, do what you can do get some tones in there man!
see if there's anything you can dress the background with to add some neutral colors
Agree with everything said. Maybe you're going for the all-white look, which has been very popular in commercials. But for a show, I think it's too cold and unfriendly. Adding some color to the clothes and some colors on the counter and walls would help. Also, I'd tone down the light in the background if possible and then add some highlights under the wall cabinets with some small puck lights.
But overall, the set looks great and so does the talent. Just needs some warmth/color and not so importantly, some modeling light in the background.
Definitely need some colors in there.
Reds, oranges, violets and rich greens in particular are all going to accentuate hunger, so I would trend towards those in their wardrobe.
Frankly, I like the hi-key, all-white look. It makes colorful food stand out and be the focal point of the show. I hate strings of peppers hanging around, gaudy wallpaper patterns, etc cluttering and distracting in the set. Make sure that you monitor your exposure, though, on a calibrated broadcast monitor. The still pix look a good half-stop over to me.
Good luck,
Ken
Not sure where you will be shooting from, but you will likely need to flag off a few of those eyesore reflections depending on camera angles. I also agree about injecting color into the set. Maybe pickup highlight or complementary colors from the show's opening graphics.
I like the lighting and the set, it looks very clean and professional. Like others have said, more color will be nice. Maybe a rack of spices in the background or add a bowl of fruits or vegtables, or maybe hang some peppers from the fan or on the wall. Anything to splash some color around.
