Request to Solomon Chase: Re: 8mm f/1.8
DanDOF
This question is in reference to the 8mm f/1.8 used by Solomon Chase in Night Light.
What was machined exactly? If you didn't have to use a focal reducer or extender how did you reduce vignetting?
Thanks if you can answer this.
What can be changed on a c-mount lens by custom machining? What is possible and what is common customisation?
I am wondering, for example, if the back of the lens mount and casing can be changed to allow a larger image circle.
