I was very pleased to see that the AF-100 came with a socket for a remote focus and iris controller. I therefore purchased a BeBob FOXI, which was designed for the likes of the DVX-100, having read that it performed well with the AF100.
Now my FOXI is a factory reconditioned unit, but I imagine that it works as it should, however it only controls the full range of the 14-140 lens when it is in the wider focal lengths.
When I zoom in to around 45mm, the furthest focus that it will allow, drops from Infinity and at 140mm it will only allow focus out to about 9 metres. The FOXI always allows close focus which is 5 metres throughout the full range of the lens, but I don't want to be limited to only using it for close up work.
Any others using this device? How do the alteratives, the Varizoom PFI and the Manfrotto 521PFI compare?
A remote controller on the pan bar is such a godsend if you mainly operate from a tripod and I can now use a manual follow-focus unit to work as a zoom control instead, allowing pretty easy control...I just need a controller that can work with the lenses full range.
