RED's performance value at 1080i/p
Kevin Rogers
Since I'd predominantly use RED to shoot lower end formats such as 720p, 1080i and 1080p, how will it's performance compare to cameras such as the HVX200 and XDCAM 350???
In particular what are your thoughts in terms of performance for dollar or value??
Notes -
Obviously what glass you use will determine quality of image but let's imagine the glass is a consistent factor.
I know we are onl guessing what sort of image RED will deliver from the specs presented but we've seen what the other two cameras are doing.
I know it's a airy fairy type of question but I would be intertested in people's thoughts.
I'm still trying to work out whether to 1. just slap down the cash and grab a HVX200, or 2. keep saving a few more months for XDCAM HD, or 3. keep saving six more months for RED - won't have any need for 2K or 4K so wondering if RED is overkill for my needs and my bank account - I like the idea of having the best 1080 image you can get though :)
PS - "my name is Kevin and I've become a camera forum addict":badputer:
Kevin,
Assuming that RED delivers their camera at the currently proposed specs. Here are my thoughts on your questions.
HVX200: I have a high opinion of the HVX. I was one of the first DP's to review the HVX for a national magazine, and I gave it a high rating. There are workarounds in the workflow, and mass storage issues that need to be addressed. The HVX is one of the cameras I've used to shoot hi-def stock footage, with excellent results. A lot of people are very happy with their HVX's, and many shooters are busy as we speak using the HVX for a broad range of projects from indies, to HDTV, to commercials, to corporate, etc.
In a perfect world, if your budget allows, a 2-camera quiver, consisting of an HVX and a RED would be a great choice. If you can only afford one camera system, you need to ask yourself what your primary intended use will be. If you do mostly smaller-budget projects where you don't need deep depth of field, resolutions above 1080, interchangeable lenses, and your clients aren't looking for high-end production equipment, perhaps the HVX would satisfy your needs. If you bought an HVX and found you needed higher than 1080 resolution for a project, you could always rent a RED camera system for that unique project. Outlay for a full-featured HVX ENG-style field production system will be around $11k USD. For a cine-style setup expect additional outlay for a matte box, follow focus, external monitor, etc.
The Sony XDCAM F350 has a suggested retail value of $25k USD. If you search hard, you can find used ENG-style HD lenses for around $8k USD, so, with tax and other necessary field accessories, your field package for an F350 will be a minimum of around $37k.
The basic price for a RED camera is currently a suggested $17.5k USD. The least expensive lens setup would be to buy a used S16 lens, currently ranging between $1.5k USD and on up, so with a battery, and RED Drive, you'd look at around $23k to get you up and running. A used 2/3" B4 mount ENG-style lens would be around $8k USD and up, so if you went that route, you'd be looking at an outlay of around $28k USD. If you shoot a lot of cine-style productions, going the S16 lens route would also enable you to shoot 2k windowed and 4:4:4 with the RED.
If you intend to bid for, or freelance for, or produce and projects in an image format higher than 1080 (2k, 4k, 2540p), RED is the only camera of the three that can supply that. If you think you’ll ever need a 4:4:4 colorspace, 35mm depth of field from the sensor, RAW files, or a frame rate higher than 60fps, RED is the only one of the three that will supply those. If you do a mixture of ENG-style (sports, reality, news, etc.) and cine-style (features, indies, commercials, stock footage) production, and you will need a combination of interchangeable lenses, 35mm/16mm/2/3” HD multiple capability accessory use, and an adjustable small-to-large form factor, RED would be the choice.
So, estimated minimum camera system outlays to get you out shooting are: HVX = $11k, RED = $23k to $28k, F350 = $37k.
You’ll have to make the decision based on your project list, and professional goals. Remember, you can easily rent equipment on a per-project basis, and include the cost in your bid to the client, studio, or network. If I was on a limited budget, I’d buy enough equipment to get me shooting, bid a lot of projects, rent the accessories for each project until I had the capital to buy what I’d use regularly, and work up into larger and larger projects. With media convergence, I’d also get a camera system that not only satisfies the genres I currently work in, but would give me the ability to branch out into production in the genres I want to expand into.
In summary, analyze the cost of the camera system, what you currently do, your future expansion, and the earning potential of the camera system (enabled by it’s versatility), and go for it. If you do it right, you should be able to pay for your in-house equipment very quickly.
I regularly use multiple film, HD, and SD cameras, depending on what the project calls for. I use cameras from all manufacturers. I rent almost everything I use, because I’m a convergence DP who tackles a broad range of projects and genres. What camera systems do I own? Because I constantly rent what I need, I’ve pared the in-house quiver down to cameras that are affordable and will get the most day-in and day-out use: a Sony Z1, an HVX200, and my higher-end camera will be a RED One.
Hope this insight helps you!
Gibby
RED camera #8
www.cut4.tv
www.4umat.com
For starters, you'll get true 1080p from the RED, which neither of the others will do as the HVX is upsampled, and the XDCAM HD is really an interlaced camera. Because you've got such a big sensor, the HD picture should be utterly superb, and the compression scheme is much more modern too. I think it will win in image quality terms.
Graeme
Thanks Graeme! I definately agree with what you said about comparative 1080p image quality. In covering many bases in my post I forgot to mention that. I guess I was emphasizing the economics of the decision and overlooked mentioning the tech behind the comparative images. Image quality will be a big sales point to potential clients and networks, so in essence image quality is an economic factor in how much revenue a camera system can generate, along with multiple image format choices, lense options, etc.
Gibby
RED camera #8
www.cut4.tv
www.4umat.com
Everyone is right here.. the HVX is a hellofa camera, and in the 5k price range its hard to beat. But Graeme is right.. you get real true 1080 resolution with the RED camera (and above).. Personally to me the HVX is a killer 720p camera and is the mode i shoot at 99.9% of the time. Depth of Field is gonna be a big selling point for the Red though beyond resolution, and all the adapters out there you can pay $10k + for to get that depth of field kinda puts the two cameras on an even price point.
Both cameras can live together very well. Red uses HVX's right now... you can buy an HVX and use it today. Since both cameras use a tapeless workflow, its nice to get all the kinks out of that workflow with a HVX so when the RED comes you dont hit that learning curve.
My thoughts
My thoughts
Graeme and Gibby are extremely knowledgeable guys, and I'm not arguing with what they say, but here's my take on it:
1.) For starters, as Steve points out, the "out the door" cost of the cameras is quite different, roughly 2X price difference as properly equipped to go out and do real shooting. So you have to ask yourself - would I rather have one RED or two HVX setups?
2.) While technically quite true that the RED shoots higher end formats (2K, 2540p, etc.), I don't think that is going to be used very often on a percentage of projects basis - I think it will be used as 1080p/i or 720p 95%+ of the time, simply because of the relatively low demand for 2K and higher work out there in the overall range of jobs. Now, some might buy a RED and focus on 2K+ work, and that's great, but my guesstimate based on folks I talk to is that HD work will be the bulk of what it's used for, among other reasons because that is what is reasonably easy to post with, assuming the "FireWire it over" workflow works as advertised with a QuickTime or AVI codec.
3.) I think the frame rate issue is a more substantial factor than the "above HD resolution" issue - HVX is uniquely flexible at its price point to allow, what is it, 4-60 fps? That's great. The F350 does not - you've got a functionally resolution limited 24p, 25p, 30p, and then full res 1080i50 and 1080i60. RED will offer up to 60fps progressive, and even 120 fps progressive using windowed 2K.
4.) But I think that, by FAR, the dynamic range, contrast, and image sharpness that the RED specs imply will be the deciding quality factor for most. Sampling down, rather than up, to 1080p/i will give a sharper image, not to mention the compression artifacts should be fewer and less noticeable with the wavelet based stuff RED is talking about so far. The 1/3", 960x540 dual pixel shifted 3 CCD setup on the HVX is not bad, but the MUCH larger sensor, with larger individual pixels, and higher resolution of the Mysterium SHOULD provide a superior image, based on the specs we've been given so far. But IBC (if footage shown there) will be the ultimate proof.
5.) And the glass - you can't change the glass on the HVX, period, so it is NOT an "all things being equal" scenario. Depth of field, choice of lenses, etc. The HVX and RED aren't really in the same category, and that's OK - the HVX is a fraction of the price, and a good bang/buck.
The F350 is really the appropriate comparator for RED, or Panasonic's upcoming DVCPRO HD new camera that will cost $20-$30K.
My $0.02.
-mike
Excellent comments all.
One comment. Steve said: "... If you do mostly smaller-budget projects where you don't need deep depth of field, resolutions above 1080 ...".
I think you meant shallow depth of field. I bring this up because Stuart English recently made a similar remark. I assume you both simply "misspoke".
Good point Mike.. i was trying to compare price points by comparing the HVX with a P+S mini35 or a Movietube, in that rate they are both comparably in price. But of course, out of the box, the HVX takes stunning images at a $6000 price point (without cards)
yes.. most of us will use 1080p modes 95% of the time. But i have a feeling if the image is good enough, there are a few cameras out there in big studios that will be shooting 2k-4k 95% of the time.. and that small fraction of cameras is probally going to also do 95% of the convincing of the capability of RED.
The HVX officially supports 12-60fps. With a small hack it can go from 2fps-60. This feature is what kills the competition though in my eyes.. the resolution, as you said, is not a selling factor.
Im glad you mentioned dynamic range.. as its something that people looking at digital kinda have just crossed off the list. I dont know if RIGHT NOW people are really buying into RED for the dynamic range alone, its kinda like a nice bonus. But, if it does hit the advertised latitude, hell even if it hits 11 stops, its gonna make a big, big wave. And DP's around the world will start sending Jim Flowers.
yes.. thats what i was getting at with the mini35 options. Its changing glass but kinda not really.
My $0.02.
the HDX900 is very cool camera, i had alot of time to play with it already. Deep down i wish it had P2 slots. But it definately is top of the market right now, and it will be interesting to step back and look at the field when everything is on the streets.
I think you meant shallow depth of field. I bring this up because Stuart English recently made a similar remark. I assume you both simply misspoke.
I think your right.. deep is what people are trying to get away from.
Thanks Greg, you're right, I meant to put shallow DOF, but in spelling it all out, "deep" somehow got typed. Good catch!
Whether we shoot ENG-style, cine-style, or both, the golden ring is a camera system that will enable shallow DOF when we need it.
Gibby
RED camera #8
www.cut4.tv
www.4umat.com
I have looked at the pros and cons of purchasing a camera as a newcomer. More than a few on this forum have said they expect to keep a camera for three years and then upgrade. How much would you get for a camera with a limited shelf life often superseded by the latest cameras offering more for your money than previous cameras. How much added extras specific to the camera are re-usable on a new camera. If the lens gets damaged and it is a fixed lens what then? P2 as an example is hugely expensive for anyone thinking of filming for long periods during the day. If as suggested in various posts the price of p2 will go down substantially in the next couple of years, what is it then worth should you decide to sell? Some guys have already spent $5,000 on these cards.
It seems to me that most people rarely get the maximum capabilities out of their camera. How long would it take most experienced videographers to get pretty used to working with a newly purchased camera? Judging by the many posts i have read it is months rather than weeks (for me it would probably be a year!).
What do videographers really think of 3 ccd cameras in the prosumer range in terms of low light capability. XLHI said to be similar to XL2 and hvx 200 has been spoken about in numerous threads. Also if i have read correctly at 1080p you are looking at requiring over 2 million pixels to get the maximum quality without some form technology to get the required picture.
Red is expected to be usable for a decade!!! If you decided to sell Red after three years how much might you get for it (or lose on it) compared to the above cameras.
If you keep it for ten years just think of the times spent utilising the camera once you do get the hang of it instead of learning all over again with a new camera every three years. If Red does succeed and the camera is all it might be it will be well sought after. Those with experience with Red could possibly find themselves in demand for hire with camera?
Red as Steve said, opens up so many possibilities for you guys that if i were a pro i would be saving like mad to get one (doing so and i am a beginner!!):)
Michael
bingo michael.. remember, even the SENSOR on RED is upgradable.. so theoretically it can last just as long as the good old Russion K 35mms....
Mike the Beginner,
I think you display one of the best traits a beginner can - an eagerness to learn from veterans. Every veteran on this thread, or anywhere else in the TV, video, or film world, was a beginner at some point. Nobody is born knowing anything - we start absorbing knowledge at birth. If you want to keep your knowledge base in a dynamic warp drive for your entire career follow this one simple principle:
"The more you learn, the more you should realize you don't know" - a Chinese sage
In other words, keep an open mind, be an "info sponge", and pick the brain of everyone in this industry that has more knowledge than you!
Though you want to always keep learning, eventually you'll arrive at this plateau:
"Be respectful to your superiors - if you have any" - Mark Twain
The danger then is to think you have all the answers, and at that point your learning slows or stops.
Comb through every tech board and forum you can find, but balance that with constant shooting. I've been shooting motion footage and still photos footage for a long time. I shoot almost every day, and when I go out to shoot I learn something new every single time.
The three elements to success in this industry are: talent, experience, and technology. You’re born with talent. You pay dues on location shooting to get experience (but you can fast-track that by picking experienced brains). You must constantly comb tech forums to learn about technology.
This is a dynamic profession, never static...
Gibby
RED camera #8
www.cut4.tv
www.4umat.com
good thoughts
good thoughts
We are very luck to have these forums with the likes of Gibby, Jarred Land and Mike Curtis - PS Mike I'm daily visiting your site as well as this one and DVinfo.
These thoughts only confim my dream of a RED purchase - we'll be able to get super excited if the footage this fall delivers on the specs - in fact I'll pop a bottle of bubbly if it delivers on expectations!
Dynamic range is a huge plus for this camera and I'm surprised it doesn't get discussed more often. From my relatively unexperienced take (compared to the rest of you guns) this is as important as higher resolutions. I do a lot of outdoor shooting (often in harsh light) and a large dynamic range is going to be beautiful!
also the point that RED's value should be long term as opposed to the other rigs is a strong point that I keep reminding myself.
The variety of work you do Gibby is something that I aspire to. Thanks for al your post, your logic thinking and openness in sharing your experience.
Now. anyone know where there is a S16 lens forum like this?????
I'll be looking to deck out my RED with a used S16 zoom and a couple of other chepaer lense to get me started - but I've never dealt with these lenses and I need to learn more!
I'm thirsty :beer: :cheesy:
Not just in the big studios...specially 2k scaled, for instance, to 2.39:1 purposes. And yes, for some, it will be 95% of the time.
You can also consider starting out your Red package with still primes. I know my Nikkors can make incredible blow ups on my 12mp d2X, 20"x30" easily. The Red one is 11mp so as long as you can handle some less than ideal focusing gears then you can start shooting with just a $50 50mm prime.
Hey Braddah Nalu,
Are you from Hawaii? With a handle like Nalu (Hawaiian for "ocean"), I'm guessing you are, or you hang out by the ocean a lot. Same here...
I've worked all over the world, especially across Polynesia. For about 15 years I worked in Hawaii for large portions of each winter, directing and shooting tons of programs. For example, I was field producer, director, and primary cameraman (all 3 simultaneously) for the ESPN series "Hawaiian Sports Adventure" (20 half hour programs), where we just went from island to island profiling all the cool things to do in the air, in the water, and on land. My wife is a longtime Production Coordinator, so we traveled and worked together on those projects - just mobile crews of three, me, production coordinator, and talent. I was shooting Beta SP, plus mounting POV lipstick cameras on everything and everyone. Hawaii Visitors Bureau was a major supporter of the series, and Team Unlimited, then Event Marketing, produced the series. My work on those projects was contracted to my company through a company named DynoComm, which was owned by my brother Alan, like me, an Emmy-winning producer/director/DP.
I'm developing some projects that may take us back to Hawaii - this time to shoot with RED cameras! I'll be receiving one of the first production models of RED (#8), and I'd love to test it out in Hawaii. If you're based in Hawaii, when we come there you can hook up with us, check out the camera, and I'll give you some stick time on it.
Thanks for the kind words! When I first started in this business, and many times since, more experienced individuals stepped up to help fast-track my learning curve, including two of my own brothers who are award-winning professionals in the TV/film industry. I mentor a lot of young people, online and on location, because to me it is completing the circle and giving back to the system, in honor of those who helped me when I started. It's good Karma, or whatever you want to call it...
To keep this post on-thread, 1080p, with 2/3" HD ENG-style lenses for action, S35 or S16 lenses for creative montages, will be what we shoot for our Hawaiian programs. Stock footage is also a big part of my business, so I'll probably shoot the stock in 2k Windowed, which licensees can easily down-res to 1080p if they desire. One advantage of shooting RED in 2k Windowed with S35 or 35 lenses, especially for long focal length sports and nature footage, is that the focal length is doubled, assuming that we can effectively store the massive amounts of data in a mobile configuration shooting 4:4:4 or 120 fps RAW. I may also shoot some 4k and 2540p stock footage in Hawaii, but I feel 2k Windowed and 1080p would be the sweet spot for most mobile travel and tourism stock footage.
Let's take specific plans about connecting in Hawaii offline. You can find my email address on my Cut4.tv web site.
Like you, I also read DV Info and HD for Indies daily - good sites!
RED - eeets da kine braddah!!
Gibby
RED camera #8
www.cut4.tv
www.4umat.com
No doubt - for certain shots. But for wide establishing shots, wide scenery stock footage, and many other similar shots, deep DOF is exactly what we need to achieve. So, a camera/lens combination that enables setup of shallow DOF, deep DOF, and everywhere in between is the ticket - and RED should be capable of that, depending on the lens, lens format, and image format combination in use.
Gibby
RED camera #8
www.cut4.tv
www.4umat.com
For me, I'm more concerned with blowup to film, and having the use of cine lens and accessories.
Frankly, i've been underwhelmed by 1/3" blow ups, and if you are going to use this level of gear, at this price point, RED seems best...(if they deliver)
And if I need 1080, for music vids, or straight to DVD, then it's there. I've been waiting for a camera not to be the obstacle in the production process, or a question mark for distributors. Hopefully that day has come.
I also think I'll purchase an acceptable used lens, and rent the rest for specific applications. If RED produces a decent zoom, in the middle, at a cool price then even better.
Having a good dynamic range, sensitivity, colours, and reduction of video artifacts on the big screen makes a huge difference (for film blowup).
Gibby
RED camera #8
www.cut4.tv
www.4umat.com
Exactly Gibby. I would love to use this camera to give panoramic shots real justice. Ever since I saw John Ford's films in colour, I've wanted to do something similar...also, the poetry of Malick's nature shots are another inspiration.
I also think we'd be surprised at how many people will use 2K, aiming for theatrical release. We forget that the potential of this camera will allso hit foreign markets too. Hopefully, some of the labs in Toronto, are keeping a close eye on RED's development. It could be an extremely popular alternative option for entrpereneurial filmmakers, or those with mixed financing, and foreign markets.:beer::beer::beer:
Cheers.
RED#wish I was higher
