Stephen W
I was thinking about Redcode Raw 4k, which will shoot at up to 30fps in 16:9, then got thinking about s35 ratio (let's call it 2.4:1 for the sake of argument!) and how best to use the full image sensor.
The thought that occured to me is that (using a windowed mode) would it be possible to take advantage of the full sensor width (4520) in a 2.4:1 ratio and still record using Redcode?
It seems to me that, for that big widescreen cinema experience, it'd make sense to shoot say 4520x1890 - making full use of the frame width whilst saving on the height. Compared to 4096x2304, I believe you'd actually have a slightly lower data-rate (it's actually about a million pixels less). It seems at the moment if you want to shoot 2.4:1 using Redcode, you'd have to do it 16:9 and then crop it, which seems a waste of data.
If we could get a slightly higher horizontal res but at a lower data-rate, surely it'd make sense?
