acrochordon
http://www.sensirion.com/en/04_cmosens_technology/02_humidity.htm
RED needs a way of sensing if high humidity gets in the camera. This might be it. Maybe it is overkill. It depends on how expensive this chip is.
Humidity sensors with CMOSens®
Capacitive humidity sensor principle
In addition to the resistive method, the capacitive measurement principle, above all, established and proved itself as a standard in the past. For this principle, the sensor element is built out of a capacitor. The dielectric is a polymer which absorbs or releases water proportional to the relative environmental humidity, and thus changes the capacitance of the capacitor. This change in capacitance can be measured by an electronic circuit. This allows the relative air humidity to be determined.
For humidity sensors with CMOSens® technology, a "micro-machined" finger electrode system with different protective and polymer cover layers forms the capacitance for the sensor chip, and, in addition to providing the sensor property, simultaneously protects the sensor from interference in ways previously not achieved.
Humidity, temperature and dewpoint
The temperature sensor and the humidity sensor together form a single unit. This also enables an accurate and point-precise determination of the dew point, without incurring errors due to temperature gradients between the humidity and the temperature sensors. Through the unique linkage of these sensor elements with the signal amplifier unit, the analog-to-digital converter, the calibration data memory, as well as the digital, bus-ready interface, all on a surface area of a few square millimeters.
Highest stability and performance
Total coverage with condensation or even immersion in liquid present no problems whatsoever. Over two years of hardness tests have already shown this result.
The signal amplification near the sensor allows the polymer layers to be optimized not for the signal strengths, but rather for long-term stability, which is significant for numerous applications. The analog-to-digital conversion, which is also performed "in place," makes the signal extremely insensitive to noise. A checksum generated by the chip itself is used for additional reliability. Last but not least, the calibration data loaded on the sensor chip guarantees that Sensirion humidity sensors have identical specifications and thus they can be replaced 100%. Other obvious advantages are the very short response times (4 sec at 1/e), high precision (±2% to ±5% according to configuration), as well as very low power consumption (< 3mA standby).
Digital Interface
Humidity and temperature sensors with CMOSens® technology can be connected directly to any microprocessor system by means of the digital 2-wire interface, which minimizes the system development times, saves costs, and leads to a significant advantage, especially for high-volume applications.
Digital Interface
