Red Hub
jnatalie
People have mentioned a battery plate that when you slide the red onto the tripod, the tripod has an integrated charger...
...well, why not an entire hub? Integrated 6-8 channel mixer with phantom power, powered off of the same tripod. Further, a 9" widescreen lcd monitor, powered off of the same hub.
Create an innovative mechanism that the hub could be attached to so that you can add the mixer, lcd, external recording device, etc as options as you go. You can go as far as having an onboard "mini" laptop so you can run programs like "DV Rack (or 4k Rack) :) "....
