should i dare say it ..
maybe it's the NIKOR lens ???
You know, it might very well be. Nikon lenses are designed to be tack sharp and they don't have to adhere to the same rigid properties with regard to breathing etc that cinema lenses do.
For sure Jarred!Jarred Land said:That lens motor isnt controlled by the camera, thats controlled via Remote, so Jim stands correct... But Curt for sure makes things alot easier.
Emanuel said:PS -- Don't worry this apparent misunderstanding is only a pretext in order to push for the tool coming from Curt -- a 3rd party dvxuser.com fellow! ($3,500 up to $5,500 is a real indie offer as well your camera!)
Emanuel said:A Nikon vs. Zeiss ZF comparision:
http://www.kenrockwell.com/nikon/50-comparison/vr.htm
Unfortunately, it seems the Nikon results are better though this reviewer is a Nikon/Nikkor based. And they're not manufactured by Zeiss in Germany:
http://www.kenrockwell.com/nikon/50-...ison/index.htm
Yes I know Chris!Chris Kenny said:Heh. That's not exactly a fair test. The Zeiss is shot at f/1.4, the Nikon at f/4.8. The reason this makes sense in the test is because the reviewer is testing a Nikon image stabilization feature which allows one to shoot longer exposures without introducing unwanted blur as a result of camera shake. Even if RED supported this lens feature (highly unlikely), you couldn't shoot 24 frames per second with a 1/5 second exposure time!
Of course! I'm just driven by curiosity.Poi Boy said:I don't really think it is ment to be a fair test for Red cine style use but gives you an idea of the quality of todays slr lenses.
Aloha
-A
Jannard said:The only valid tests will come when we cement down a sensor absolutely perpendicular to the light path (Frankie is a bit too crude for this). Then when the back focus is set properly, everything coming from Red will crispen up a bit and lens comparison tests will be more valid.
Jim
