.red bars on audio levels
dhffhd
If my audio is just tickling the red bars on the audio levels meter on the dvx 100, does it need to be brought down a tad ? It doesn't sound like I'm blowing out the sound on my headphones, but just don't know how much I can get away with.
Thanks in advance.
Re: .red bars on audio levels
Panasonic picked a funny way to display the levels. The red bars start lighting up at -12dB, well within the safe zone for recording. Each bar represents 2 dB, so the last red bar represents 0 dB. The thin red bar means you're over 0 dB--or overloading the signal. I like to see my peaks topping out at about -6 dB which is lighting up the first 3 red bars. This leaves 6 dB of headroom for really loud transient peaks. If you're not hitting the red bars, you're recording at below -12dB, which is a bit low.
Thanks Barry,
I was wondering about that too. The first couple of red bars on my 100A just about hit -12 on the Vegas meters.
Ken
Yes, if anyone at Panasonic is listening - PLEASE consider standard Green->yellow->red bars for future updates!
For music recording, when I can do a good sound check, I run up to the penultimate bar with no problems. But if you're not very sure about what you'll be recording, keep it a notch below that to allow for surprises...
I also remember reading in another thread that you can set one channels audio level and little lower/higher than the other one just to be safe and have a backup if youre not happy with one of them.
yeah I do that to recording two different audio levels on different channels
