recording orcehstral music with 744t. Looking for mic recomendations and techniques
Not saying you need to provide a mono deliverable but there are many places in the chain down to the final viewer where a signal that starts out in stereo can get collapsed to mono.
Playback on a DVD player that is connected to the TV through an RF adapter instead of the AV outputs - most of the converters that put the signal on an unused VHF channel are mono.
That is a semi legit situation. It however only applies to a really old set up. At least in the US you are not going to find many/any TV's (that are not old tube boxes) that are connected that way. I have one of those old boxes but it still has composite inputs. Even the cheapest "toss-away" digital converter boxes go out at least stereo. So what are we talking? Potentially 1%-5% at most.
Broadcast is distributed on a cable system that converts stereo into mono on the head-end. Many smaller cable systems are pretty far behind the curve.
That isn't my experience (again in the US YMMV). It would be hard for any cable company around to be down converting to mono and still have customers. The US is all digital broadcast and that caries 5.1 (whether the show uses them all or not).
Viewed on a small-screen TV whose 'stereo' speakers are so close together they may as well be mono.
Not a valid point at all because from a perception point your are correct but the channels are not going to be summed so there won't be the cancellation issue.
Accidental collapse by a minimum-wage techno-turkey in the station who's asleep at the switch - not too long ago I tuned in to an episode of the series "Things That Move" on National Geographic Canada. It's a very narration rich program but for the entire show, the only audio audible was the FX track (steam engine sounds and other railroad sounds) and a tinny-sounding music track. Commercials were fine but the show was completely devoid of dialog. Obviously the stereo channels were out of phase and somewhere in the broadcast chain the audio had been collapsed to mono with resulting cancellation.
A somewhat valid point but you can't base your decisions on the worst case scenario of idiots trashing your deliverable. If you did you would need to go mono and B&W, and close caption everything incase the sound went out and describe everything incase the picture went out. I'm not sure how you cover when they both go out ;~)
In short if you ASSUME your audience is going to have equipment less than say ten years old and that they haven't totally botched the setup. And you assume your audience is not out in the backwoods of??? where the cable is still at 1970's standards. THen you don't need to worry about mono compatibility.
Now this was about a documentary on a chamber orchestra. And it's shot in the US. So it's primary audience is probably film festivals, art houses and PBS. You don't need to worry about mono compatibility. Yes some idiot may trash your show, but that is the case anyway. There are a million ways your show can get trashed in the chain, mono compatibility is VERY low on that list.
To use your example IF that show had been in mono you would have had total cancellation and no sound at all. So making it more mono compatible would have made the situation, if anything, worse. Ironically that show must have been very mono in the first place if the music cancelled. The phase inversion probably happened in that chain where the idiot collapsed the signal to mono, it certainly would not have left and mix stage like that.
Know your market and act accordingly. For 99% of the time mono compatibility is no longer an issue, at least in the US. I don't know other markets so YMMV. If mono IS a significant part of your audience by all means go for it. In that case an omni center stage is probably your best bet, anything else is going to have some level of cancellation.
That's true...I could only demo it on headphones with a shaker.
Yes on headphones some of these devices sound incredible.
I just notice the "member titles". I kind of like sound ninja, and was a bit surprised at my post count, I really do need to get more work ;~)...
then I looked at yours! My god man do you never sleep.
WOW.
If anyone would be so kind for feedback on the quality of my recording, I'd be delighted if you gave a listen. I can email you a small mp3 snip it, unless you recommend a better method. They actually didn't play all that much, 20min sets for kids. Having kids made the recording process much less stressful, but I would like to improve on my set up being that next time no kids.
I had to put the mics right in front of the conductor. no where else but maybe the far out sides, but I was to afraid of kids nocking over the mics. Let me know if you would like a listen.
thanks
Love a listen
Love a listen
thanks
Matt from Australia here. I would love to have a listen to your recording. My email is mattygc@bigond.net.au
