Recorder With Good Preamps?
tommygdawg
Hey all,
I've had the Tascam DR-1 for quite sometime now and it has served me okay, but I'm looking to upgrade to something that won't give me a metric nut-ton of hiss when I boost the gain so I can move the shotgun mic more than a foot from the person I'm recording. I've looked into the H4n but I hear the preamps aren't that great. Any good choices around the $300 dollar mark? Also, what about buying a standalone preamp to be the middleman between the mic and the recorder?
Thanks!
- Tommy
If you don't mind the extra piece of gear, a good pre-amp middleman will probably offer up the best value/quality. Even on my Tascam 2488 I like to run vocal mics through a stand alone pre-amp.
Go to Guitar Center/B and H, etc online and take a look. There's some pretty nice small form, relatively inexpensive pre amps available that will give you more headroom/less noise.
This does belong in the Audio forum.
You aren't going to find a recorder with good pre-amps in the $300 range. You may find one with comparitively better pre-amps (like the DR100 vs. the H4n), but not one with good pre-amps. The lowest you can expect to spend and get formidable performance is about $600 for the Fostex FR-2LE. Next up: the TASCAM HD-P2 or DR680, both about $1000 (and a choice between 2-track/stereo recording and six-track recording). And it'll be more expensive if you want to get either the FR-2LE or the HD-P2 with an Oade Brothers modification.
If you want to add a pre-amp to the front end of your recorder, the budget option is the Sound Devices MM-1. The MP-1 is less expensive, but the extra features of the MM-1 are worth the investment. The next step up is the MixPre, or better the MixPre-D. All are battery operated.
If you are after high quality mic preamps for low cost, you might want to look at Naiant mic preamp boxes : Naiant Mic Preamp Boxes : Starting at $200
Then feed the output from the Naiant box to a Sony M10 recorder : Sony M10 Recorder $229 at B&H
I've read that the Sony M10 has a noise floor in the -85 dB range, which is very good for a low cost recorder.
...Or you could play it safe and buy a JuicedLink box and feed the audio from this to the Sony M10 : juicedLink CX231 Audio Mixer and Preamplifier : $299
JuicedLink boxes have pretty good preamps.
You can find a ton of info on lots of unique audio solutions on the The Tapersection Forums
Thanks much! Any specific thoughts on the quality of the preamps in the JuicedLink lines? Specifically, the much cheaper version without Phantom Power (because I don't need Phantom power for this application).
Just another thought, you might also consider the Sound Devices MP-1 mic pre, and run that into your DR-1. Very high quality, clean gain.
I have only used the model with phantom power, but I imagine they would be the same. Unless this is a one off purpose that you will never use again for anything else, I would recommend getting the model with phantom power, as it opens up a much larger range of professional mics that you can use ( most pro mics are not self-powered ), and will be easier to sell if you decide to upgrade to something better.
You raise a good point, I'm just trying to weigh which things to spend money on. I'm shooting a huge project this summer and a $100-200 dollars or more saved would be REALLY nice.
