starcentral
What are the pros & cons and differences between some of the "low cost" digital recorder alternatives for the F35?
I'll update the first post here with any findings and further details. Originally my post looked at three recorders specifically but fellow DVX users have since noted some additional non-Sony recorders for consideration so I've added them to the list.
Then in typical fashion I went crazy, and started researching more and more and more...
12-bit 444 and 10-bit 422 up to 50p support
Odyssey 7Q ~ $1800
- wide range of codecs (some require licensing costs)
- supports dual link (required to get 12-bit 444 or 10-bit 422 HD 50p)
- 7.7" 1280x800 OLED touchscreen
- Uses proprietary drives
- Waveform, histogram, vectorscope, false color, zebras, 3D LUTs
Pix E5/E7 ~ $1500/1600
- ProRes Proxy all the way up to Apple ProRes 4444 XQ
- no dual link but with SDI multiplexer (AJA 3GM for $800 USD) you can get 12-bit 444 ProRes or 10-bit 422 HD 50p
- 5"/7" 1920x1080 IPS touchscreen
- Uses SpeedDrive or mSATA drives
- Waveform, histogram, vectorscope, false color, zebras, peaking, 3D LUTs
- 2x or 4x tapZoom
Pix240i ~ $3300
- 10-bit 422 ProRes / DNxHD *Up to 30p only on F35
- 5" 800x480 IPS screen
- Supports 1:1 pixel viewing
- Uses Approved SSD drives
- False Color, 2-level zebras
Codex
- 12-bit 444 DPX up to 30p
- From 31fps to 50 fps 10 bit 444 DPX uncompressed is possible
- Uses proprietary 512 mags
- Needs Data Transfer Unit for offloading
Gemini
- Uncompressed RGB 10-Bit 444 Recording into DPX file format up to 50p
- Uses Convergent Design SSD media drives
- 5" 800 x 400 screen
- 1:1 pixel viewing
- Can do 12-bit 444 Uncompressed with AJA LUT Box (see Film Scientist blog)
Blackmagic Video Assist ~ $495
- *Up to 50p with SDI multiplexer
- 5" 1920 x 1080 135 degree angle colour touch screen
- 6G-SDI
- Histogram, Zebra stripes, focus peaking
- Uses SD Card Media
Atomos Shogun 4K HDMI/12G-SDI Recorder ~ $1495
- 7" 1920 x 1200 colour touch screen
- 12G-SDI
- Waveform monitor, RGB parade display, Luma overlay, Vectorscope with zoom, focus peaking
- Uses HHD or SSD
10-bit 422 up to 30p support
AJA mini ki pro ~ $700
- 10-bit 422 ProRes *Up to 30p only
- Single Link 4:2:2
- Uses Compact Flash Cards
Atomos Samurai Blade ~ $500
- 5" 1280 x 720 IPS screen
- Single Link 4:2:2
- Uses standard HHD/SSD drives
- NO support for 1:1 pixel viewing
- Waveform, vectorscope, luma parade, RGB, false color, zebra, focus peaking.
Hyperdeck Shuttle V2 ~ $300
- 10-bit 422 ProRes / DNxHD / Uncompressed *Up to 30p only on F35
- Single Link 4:2:2
- Uses SSD Drives
Other
Sony SR-R1
- 10-bit 422 220Mb/s
- 10-bit 444 400Mb/s
- 12-bit 444 880Mb
- Uses SRMemory Cards
Sony SRW-1
- 422 1080p 60p
- 444 RGB
- Uses HDCAM-SR Video Cassettes
Teathered or wireless solutions
Blackmagic design ultrastudio mini recorder ~ $137
- F35 teathered via SDI for computer capture via thunderbolt
- 10-bit 422 up to 30p
Blackmagic Intensity Extreme ~ $280
- Will convert SDI to HDMI at device for extra monitoring if desired
Teradek Bolt Pro 300 Wireless ~ $2990
- F35 wireless SDI transmitter to receiver with SDI *You still need a recording option
Odyssey 7Q ~ $1800
- 2x or 4x tapZoom
Pix240i ~ $3300
Codex
Gemini
- 1:1 pixel viewing
- 6G-SDI
- 12G-SDI
- Uses HHD or SSD
- Single Link 4:2:2
- Single Link 4:2:2
- Single Link 4:2:2
- Uses SSD Drives
Other
Sony SR-R1
- 12-bit 444 880Mb
Sony SRW-1
- 422 1080p 60p
- 444 RGB
