Raylight again
otari_99
Hello,
I've continued experimenting with Raylight demo 3.0 and Premier Pro 1.5. Some video clips on the timeline (direct drop-in MXF) exhibit what I call “the jaggies”. This is especially evident when white borders agianst just about anything . Also, those same clips appear to exhibit a jittery timing phenomena. However, some clips look excellent which exported nicely as an MPEG. All clips are 720/24pn time base, some of which are recorded at different frame rates. PP1.5 is configured per DVFilm recommendations. I've also tried numerous other Premier settings, and built Raylight AVIs with the same results.
I’m wondering if this is a Premier issue, or am I just doing something wrong?
Thanks again, folks!
Well, we gotta know exactly what "the jaggies" are! :) Could describe a number of things, including whites that are a bit too hot.
Okay. The attached jpg might give some idea. However, I'll try to post an actual screen capture tonight. The thing that is interesting is that I have some clips with bright whites that look fantastic pre and post export.
I should clarify, too that it's not just the whites but any slightly contrasting colors.
Thanks again.
