Raw .MXF files.
sheeep
I know this has been requested before, searching brings up a lot of topics from the release of the HVX, but none of the files are still hosted.
Does anyone have, or know where I could download a raw .mxf file, I want to see if my PC can handle any HD editing.
thanks
-Omar
Why not provide the specs for your computer and which NLE you will be using.
We all can give some idea based on that info.
thanks
-Omar
I would basically say you need a Core 2 Duo or better to edit HD.
You can do it with less, bu that is a rough guide.
I can edit HD on my Powerbook G4 1.67...and yes, from P2. 720, 1080...no matter. eSATA drives as media drives. Also with my Dual 2.0GHz G5...
But those ain't a PC...
My specs are sub par, but I want to see if I can at least work around it for now, working with proxy's or lower resolution renders.
P4 2.8 @ 3.36, 4GB Ram, 9800 pro, SATA 7200rpm drives.
