RAID5 versus RAID10
DC
Cinematographiliac
Now, I know many of you editing your DVCProHD footage will be looking into mass storage solutions.
There's a sea of options out there. Let's focus now on data integrity with the almighty RAID.
I thought this was a very good read:
RAID5 versus RAID10 (or even RAID3 or RAID4)
by Art S. Kagel
First let's get on the same page so we're all talking about apples.
What is RAID5?
OK here is the deal, RAID5 uses ONLY ONE parity drive per stripe and many
RAID5 arrays are 5 (if your counts are different adjust the calculations
appropriately) drives (4 data and 1 parity though it is not a single drive
that is holding all of the parity as in RAID 3 & 4 but read on). If you
have 10 drives or say 20GB each for 200GB RAID5 will use 20% for parity
(assuming you set it up as two 5 drive arrays) so you will have 160GB of
storage. Now since RAID10, like mirroring (RAID1), uses 1 (or more) mirror
drive for each primary drive you are using 50% for redundancy so to get the
same 160GB of storage you will need 8 pairs or 16 - 20GB drives, which is
why RAID5 is so popular. This intro is just to put things into
perspective.
RAID5 is physically a stripe set like RAID0 but with data recovery
included. RAID5 reserves one disk block out of each stripe block for
parity data. The parity block contains an error correction code which can
correct any error in the RAID5 block, in effect it is used in combination
with the remaining data blocks to recreate any single missing block, gone
missing because a drive has failed. The innovation of RAID5 over RAID3 &
RAID4 is that the parity is distributed on a round robin basis so that
there can be independent reading of different blocks from the several
drives. This is why RAID5 became more popular than RAID3 & RAID4 which
must sychronously read the same block from all drives together. So, if
Drive2 fails blocks 1,2,4,5,6 & 7 are data blocks on this drive and blocks
3 and 8 are parity blocks on this drive. So that means that the parity on
Drive5 will be used to recreate the data block from Disk2 if block 1 is
requested before a new drive replaces Drive2 or during the rebuilding of
the new Drive2 replacement. Likewise the parity on Drive1 will be used to
repair block 2 and the parity on Drive3 will repair block4, etc. For block
2 all the data is safely on the remaining drives but during the rebuilding
of Drive2's replacement a new parity block will be calculated from the
block 2 data and will be written to Drive 2.
Now when a disk block is read from the array the RAID software/firmware
calculates which RAID block contains the disk block, which drive the disk
block is on and which drive contains the parity block for that RAID block
and reads ONLY the one data drive. It returns the data block. If you
later modify the data block it recalculates the parity by subtracting the
old block and adding in the new version then in two separate operations it
writes the data block followed by the new parity block. To do this it must
first read the parity block from whichever drive contains the parity for
that stripe block and reread the unmodified data for the updated block from
the original drive. This read-read-write-write is known as the RAID5 write
penalty since these two writes are sequential and synchronous the write
system call cannot return until the reread and both writes complete, for
safety, so writing to RAID5 is up to 50% slower than RAID0 for an array of
the same capacity. (Some software RAID5's avoid the re-read by keeping an
unmodified copy of the orginal block in memory.)
Now what is RAID10:
RAID10 is one of the combinations of RAID1 (mirroring) and RAID0
(striping) which are possible. There used to be confusion about what
RAID01 or RAID10 meant and different RAID vendors defined them
differently. About five years or so ago I proposed the following standard
language which seems to have taken hold. When N mirrored pairs are
striped together this is called RAID10 because the mirroring (RAID1) is
applied before striping (RAID0). The other option is to create two stripe
sets and mirror them one to the other, this is known as RAID01 (because
the RAID0 is applied first). In either a RAID01 or RAID10 system each and
every disk block is completely duplicated on its drive's mirror.
Performance-wise both RAID01 and RAID10 are functionally equivalent. The
difference comes in during recovery where RAID01 suffers from some of the
same problems I will describe affecting RAID5 while RAID10 does not.
Now if a drive in the RAID5 array dies, is removed, or is shut off data is
returned by reading the blocks from the remaining drives and calculating
the missing data using the parity, assuming the defunct drive is not the
parity block drive for that RAID block. Note that it takes 4 physical
reads to replace the missing disk block (for a 5 drive array) for four out
of every five disk blocks leading to a 64% performance degradation until
the problem is discovered and a new drive can be mapped in to begin
recovery. Performance is degraded further during recovery because all
drives are being actively accessed in order to rebuild the replacement
drive (see below).
If a drive in the RAID10 array dies data is returned from its mirror drive
in a single read with only minor (6.25% on average for a 4 pair array as a
whole) performance reduction when two non-contiguous blocks are needed from
the damaged pair (since the two blocks cannot be read in parallel from both
drives) and none otherwise.
One begins to get an inkling of what is going on and why I dislike RAID5,
but, as they say on late night info-mercials, there's more.
What's wrong besides a bit of performance I don't know I'm missing?
OK, so that brings us to the final question of the day which is: What is
the problem with RAID5? It does recover a failed drive right? So writes
are slower, I don't do enough writing to worry about it and the cache
helps a lot also, I've got LOTS of cache! The problem is that despite the
improved reliability of modern drives and the improved error correction
codes on most drives, and even despite the additional 8 bytes of error
correction that EMC puts on every Clariion drive disk block (if you are
lucky enough to use EMC systems), it is more than a little possible that a
drive will become flaky and begin to return garbage. This is known as
partial media failure. Now SCSI controllers reserve several hundred disk
blocks to be remapped to replace fading sectors with unused ones, but if
the drive is going these will not last very long and will run out and SCSI
does NOT report correctable errors back to the OS! Therefore you will not
know the drive is becoming unstable until it is too late and there are no
more replacement sectors and the drive begins to return garbage. [Note
that the recently popular IDE/ATA drives do not (TMK) include bad sector
remapping in their hardware so garbage is returned that much sooner.]
When a drive returns garbage, since RAID5 does not EVER check parity on
read (RAID3 & RAID4 do BTW and both perform better for databases than
RAID5 to boot) when you write the garbage sector back garbage parity will
be calculated and your RAID5 integrity is lost! Similarly if a drive
fails and one of the remaining drives is flaky the replacement will be
rebuilt with garbage also propagating the problem to two blocks instead of
just one.
Need more? During recovery, read performance for a RAID5 array is
degraded by as much as 80%. Some advanced arrays let you configure the
preference more toward recovery or toward performance. However, doing so
will increase recovery time and increase the likelihood of losing a second
drive in the array before recovery completes resulting in catastrophic
data loss. RAID10 on the other hand will only be recovering one drive out
of 4 or more pairs with performance ONLY of reads from the recovering pair
degraded making the performance hit to the array overall only about 20%!
Plus there is no parity calculation time used during recovery - it's a
straight data copy.
What about that thing about losing a second drive? Well with RAID10 there
is no danger unless the one mirror that is recovering also fails and
that's 80% or more less likely than that any other drive in a RAID5 array
will fail! And since most multiple drive failures are caused by
undetected manufacturing defects you can make even this possibility
vanishingly small by making sure to mirror every drive with one from a
different manufacturer's lot number. ("Oh", you say, "this schenario does
not seem likely!" Pooh, we lost 50 drives over two weeks when a batch of
200 IBM drives began to fail. IBM discovered that the single lot of
drives would have their spindle bearings freeze after so many hours of
operation. Fortunately due in part to RAID10 and in part to a herculean
effort by DG techs and our own people over 2 weeks no data was lost.
HOWEVER, one RAID5 filesystem was a total loss after a second drive failed
during recover. Fortunately everything was on tape.
Conclusion? For safety and performance favor RAID10 first, RAID3 second,
RAID4 third, and RAID5 last! The original reason for the RAID2-5 specs
was that the high cost of disks was making RAID1, mirroring, impractical.
That is no longer the case! Drives are commodity priced, even the biggest
fastest drives are cheaper in absolute dollars than drives were then and
cost per MB is a tiny fraction of what it was. Does RAID5 make ANY sense
anymore? Obviously I think not.
To put things into perspective: If a drive costs $1000US (and most are far
less expensive than that) then switching from a 4 pair RAID10 array to a 5
drive RAID5 array will save 3 drives or $3000US. What is the cost of
overtime, wear and tear on the technicians, DBAs, managers, and customers
of even a recovery scare? What is the cost of reduced performance and
possibly reduced customer satisfaction? Finally what is the cost of lost
business if data is unrecoverable? I maintain that the drives are FAR
cheaper! Hence my mantra:
NO RAID5! NO RAID5! NO RAID5! NO RAID5! NO RAID5! NO RAID5! NO RAID5!
[INTRO]
Today, the largest SATAII HDD holds 1TB and are inexpensive, this simplifies a lot how to design a reliable and compact data storage.
Take 2 of them in RAID1 (Mirror) and you get a secure 1TB storage for less than $700.
Some years ago, (the article mentions disks @ 1000$ each), HDD were expensive, and you had to think about the best RAID config to keep the best storage cost. This was discussions in IT departments for equipping servers.
[SUBJECT]
Today, life is simpler. The roadmap is clear:
- If you drive without insurance in the fast lane, take RAID0.
- If you prefer the insurance option, having a good engine, choose RAID1 (mirror).
- If you got a ticket in the fast lane, or if family grows, have a look on RAID10.
[EPILOG]
Don't build a complex RAID system with yesterday's price constraint, when byte to $ ratio is better than ever, with today's technology.
These RAIDs have the G5 look, small to big: www.caldigit.com
I have built a home-brew Raid 10, which will be part of my article in December DV magazine. Since then I have been testing a Raid from Dulce Systems, currently configured in Raid 5. The article makes ample sense when it comes to questions of data recovery and security. However, in a raid like this Dulce Systems (and CalDigit has an identical product) the direct PCi connection plus hardware raid implementation on the enclosure backplane is producting amazing data throughput. Let's put it this way-- I have been playing back 2K from the Dulce raid and not dropping a frame.
Ned Soltz
Indeed,
1) a PCI Express based RAID controller,
1+1) connecting HDD via eSATA II,
1+1+1) doubling the bandwidth with 2 pairs RAID10 (x3 with 3 pairs, x4 with 4 ...)
1+1+1+1) using brand new large (1TB) HDD technology, accessing plates faster:
> And you stack up 4 ADVANTAGES
to get a HUGE throughput
for the HUNGRIEST video format.
Another possibility to consider is the emerging RAID-6 standard, which is similar to RAID-5 but uses two drives for parity/redundancy, allowing an array to support two simultaneous drive failures.
It still has the speed issues of RAID-5 but considerably more stability, and doesn't have the cost of RAID-10's complete duplication of storage capacity.
