alpi69
Our colleague Stefan Krösbacher (krost-audiovisual) received his S-Log finally, so I rushed over there and we put the cams to a very quick shootout scene.
Both with a Samyang 85mm (his new, mine 3 years old, but should be very similar glass)
F3 in S-Log - C300 in C-Log (CP8)
both in 5600k preset
focus was at the flower, but since the C300 operator (me) is a media-slut and had to sit in the middle of the frame its focus was a bit toward the cam.
The scene was extreme contrast with fresh snow on the mountains. We had a GoPro box with small writing on it, a flower and a person in shadow.
results: as long as we kept the highlights in check it was close. Once we blew out the highlights the S-Log showed its two extra stops and the C-Log clearly fights with the snow and clouds above 100IRE. The C300 is turning the shadows blueish (something I feel it does all the time; this is why I work on a setting with blue gain at -5). But the C300 has more resolution and when highlights are held in check the C300 to me looks pretty much the same. In extreme situations the F3 (WITH S-LOG) has step though.
The C300 C-Log is a bit too saturated for a log-setting, but apart from the blueish shadows is very true to the color with only small adjustments needed while the F3 needs a lot more work in the image in post.
**EDIT: managed to upload larger images below.
