Chris Messineo
If I shot something in HD (1280 x 720) and I want to export it to standard def (but keep the same aspect ratio) what size should I use?
Thanks,
Chris
Thanks,
Chris
If I do that, then I am depending on the person I give this to to be smart enough to expand the image so it looks correct. I want to create an mov that plays in the correct ratio naturally, that is why I am thinking I need to use 720 x 405.Anders Holck said:Chris, I added some info to my old post.
You should just drag the HD sequence into a 4:3 NTSC sequence and FCP should letterbox accordingly, but unfortunately it does not work!"If you want to deliver a quicktime movie for mastering to a SD format, and want it to show "idiot proof" on 4:3 you would letterbox the 16x9 frame."
And how does one do that in FCP?l
