Questions Regarding HV10
ConspiracyPenguin
Nosey Penguin
I did an exhaustive search to find anything related to this, but couldn't, so sorry if I missed it. I am looking to purchase some new equiptment for my next project on a tight budget, and I was considering the HV20. Then I found the HV10 which also takes great footage.
I am going to get a whole new audio setup and record it on a separate system than the video, putting them together in post. But what I really need is a 35mm adapter to allow me to manually adjust focus on the camera. Where can I get cheap adapters for the HV10? Has anyone had expirience with this?
Thanks in advance for your help, and just on a side note, if I could get a good deal on an HV20 I probably would take it. So any help with the same questions in regards to the HV20 will also be accepted, although info for the HV10 is what I am looking for. Thanks again!
The HV10 isn't in production anymore and the HV20 is on it's way out the door. I bought an HV30 for $999 when they first came out a few months ago, but if you have a tight budget you can get an HV20 now for less than $700.
Thank you. I realize that the HV10 is no longer in production, but I was looking at a few slightly used ones. I am in talks now, thinking about an HV20 still. Thank.
