Peter J. DeCrescenzo
(Apologies if there's already a thread about this here; I didn't find it; please post a link if it's here; thanks!)
I'm still learning about still camera lenses & mount types. I don't have a still photography background so I find the cam manufacturers' lens mount abbreviations confusing. I'm primarily interested in shooting mostly video and to a lessor extent some stills.
I'm trying to figure out which lenses (or I guess more specifically, which lenses mount types) could be used with _both_ a 7D _and_ a GH1 using appropriate adapters.
1. Can EF or EF-S mount (for Canon APS-C) be used with a GH1 (Micro 4/3)? In other words, do the adapter(s) exist? Or are these lens mounts incompatible (don't provide full sensor coverage, or don't have rear element clearance) for use with the GH1?
2. Does it make more sense to adapt "full-frame" lenses for use with both the 7D and GH1? If so, which common full frame lens mount type(s) have adapters readily available for both the 7D and GH1?
3. Or, is it "better" for some reason to get lenses & adapters (if required) which work with either the 7D or the GH1, but not try to use one lens mount type with both cams?
I realize that some lenses' "auto" features won't be fully functional with either or both cams. I'm OK with using lenses in full manual mode if that makes it more possible or less expensive for them to be used with both cams. And again, I'm mostly interested in shooting video with these cams, more so than stills.
I hope these questions make sense. Comments welcome.
