starcentral
I just need confirmation that in Custom mode which Gamut was being used.
As mentioned in post #132 Custom Mode uses "S-gamut" and CineEI mode uses "S-gamut3.cine" and "S-gamut3". (On the F5/F55 however S-Gamut/SLog2 is an option in CineEI mode in the menu)
If you're CUSTOM mode and you turn MATRIX OFF the camera is recording in S-Gamut3 is that correct?
Nope. As mentioned, in Custom Mode there is only one single color space available, and that is "S-gamut".
More Fun:
Sony has said that "S-Gamut3" is very close to camera native color and that it is more accurate than S-gamut. They've also said that S-Gamut3 is much easier for grading - and that S-Gamut3 is less prone to color shifts when converting to other color spaces (Rec709, 2020). Also the big thing I think is that when converting to other color spaces S-Gamut3 is not dependant on the actual color temperature setting, maybe this means less color shifts but I'm not sure.
This is the best Technical Summary on Sony's Slog3/S.Gamut3 you will ever read. Straight from the horses mouth: http://community.sony.com/sony/atta...ry_for_S-Gamut3Cine_S-Gamut3_S-Log3_V1_00.pdf
