EWS
Just purchased a Glidecam HD 1000 for my GH1. I have been able to get a pretty good balance with several lenses, but I have only one major issue. If I get the unit flying in a normal position say with my right hand on the rear center to rear right of the camera I am unable to rotate very far before it goes out of balance. In other words if I were to hard pan the camera to the other side of the axis it is completely off. I was just wondering if this is normal? I cant seem to get my head around why if it is balanced in one position that is it doesn't maintain this in a 360 degree rotation. My only thought on this is that the bearing and gimble may not be perfectly at 90 degrees to the center post or just the play in the bearing is causing this.
One other note that may be helpful to someone is that I took a 6/32 screw in the sled pointing up to the plastic tensioning knob that adjusts the length of the bottom pole to aid in more precise adjustments. You can cut it to length and slightly round the end of the screw off and it will fit into the space in the clamp to help keep the sled aligned.
