Question about prices for 70D
mikcheck
Hello guys.
What would you buy? New Canon 70D 18-55 kit lens for about $969 or one with 18-135 kit lens for $1393?
Thank you
I just bought the one with 18-55, there was only 1 available and i think it's a good price for it. I hope i did it right
The 18-55 is good for a general learning lens. Enjoy the purchase. Add a 50mm f/1.8 as soon as possible for lowlight and beauty shallow dof shots. It makes an enormous difference in image quality compared to the 18-55, almost unlocks your camera's ability. If you find you do lots of wide landscapes, add a 300$ 10-18mm. A smashing ultra wide angle lens. And if you find yourself needing more reach zoom/compression get a 55-250mm STM IS.
I always advice Canon shooters to have that set:
10-18mm STM IS
50mm f/1.8 II
55-250mm STM IS
the three will cover everything you need including extreme telephoto, ultra wide angle, and lowlight/shallow dof. I don't advice the 18-55mm with them because at the wide end I would use the 10-18mm better and at the 55mm end I would use the 50mm 1.8 much better. But it doesn't hurt to have one anyway.
I don't like the 40mm pancake as it's too slow for a prime lens, especially on a s35/APS-C body where it's effectively a 60mm f4-ish. After using both I much preffered the 1.8 image, which offers significantly shallower depth of field because of the longer focal length and wider iris. It's a 80mm f2.8 equivalent, an ideal lens for people shooting and close ups. As weak and cheap as the lens feels, I never broken one even after abusing them.
Some people don't like shallow depth of field and use heavy lighting set ups, for those the 40mm 2.8 should be a better option for the better build.
The 40 can be used at 2.8 , shallowing the field a lot, and with great sharpness, and when want more 85 1.8 is more, the 50 nifty is noisy and jumpy with the STM System, not only cheap build.
Hello guys.
Sorry for the late reply but i want to thank you all for the help.
I bought 70D with the kit lens like i've stated but now i also have one 50 1.4 and 18-35 1.8, both Sigma. The image is pretty awesome.
